Transmission solenoids
200,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
SAUSHASMITH82
I have the XR model. I am told I need to replace the transmission solenoids, but I want to make sure I am getting the right parts. How many are there? I know there are more than one. About how much should just the parts cost me?
Dec 21, 2017 at 1:38 PM
Good morning my name is Roy and I will assist.
Below is the information you requested. I find highly doubtful that all the solenoids have failed at one time. What is your original issue?
Also, the price is about $60.00 to $120.00 per solenoid.
Dec 21, 2017 at 7:29 PM
STEVE W.
  • 15,403 POSTS
As Roy asked, what is the problem you are having? It would be very rare to have more than one or two solenoids failing at a time. Plus it may be that the solenoids are not the actual problem but that it is in the controller or even a mechanical failure internally. With 200,000 miles on that transmission I would be real suspicious that it is only a solenoid.
Dec 22, 2017 at 1:35 AM
SAUSHASMITH82
I apologize, it has just been rebuilt due to a broken 35R wave plate. The torque converter was replaced and the transmission reinstalled. Upon my attempt to drive it home the transmission failed about a mile from the house, mid drive. It just stopped changing gears and would not leave first gear.
Dec 22, 2017 at 9:16 AM
STEVE W.
  • 15,403 POSTS
First thing would be to check the wiring harness. It is possible there is a bent pin or simply not fully seated. But, I would also let the place that did the rebuild have a look first. This should be something covered under warranty (at least it is at the transmission shops around me).
Dec 22, 2017 at 4:16 PM
