Transmission makes a grinding noise whenever i put it in gear
175,000 MILES • 2.7L • V6 • 2WD • AUTOMATIC
BLASTERMASTER
I have the GLS model. Today I replaced the passenger side axle, inner/outer tie rods, ball joint, steering knuckle and abs sensor. After driving about twenty miles the rusted codder pin on the tie rod broke and the castle nut came off which allowed the tie rod to slip out of the knuckle. I had an extra castle nut and codder pin so I put those in but when i went to drive again the car just makes a grinding noise whenever i put it in gear. Any gear. It also rolls even when it's in park. Please advise
May 25, 2019 at 3:23 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Can you please use your cell phone to make a video of the damage/and or noise of the damage and upload it here? It would help us better diagnose the problem. thanks for using 2CarPros.
Danny-
May 25, 2019 at 10:53 PM
