Trans axle problem
140,000 MILES • AUTOMATIC
JUSJ210
Hello, i have the custom model. my CV axles went bad due to my transmission mount being broke. i had both driver and passenger replaced as well as the mount. now my uncle did the mechanics he put it back together but when we started it up i drove around the block and i noticed my speedometer is not working and it drives, but will not change gears.
Aug 10, 2017 at 2:40 PM
CARADIODOC
  • 34,408 POSTS
Chances are a speed sensor on the transmission got broken or unplugged. That will cause both symptoms you described.
Aug 12, 2017 at 3:24 PM
