There is a vibration when driving thirty two to thirty seven mph in "drive" gear, but not in second gear.
Jan 7, 2017 at 2:14 AM
JOHNNY G.JR
✓Experienced Mechanic
Front, rear, in the steering? More information needed.
Jan 7, 2017 at 3:30 AM
BUTCH JOHNSON
MEMBER
The whole car.
Jan 7, 2017 at 5:32 AM
CARADIODOC
Hi guys. Next time this occurs, hold the accelerator pedal perfectly steady, then see if it stops when you lightly tap the brake pedal. If the vibration stops for two or three seconds, it is likely being caused by the lock-up torque converter. The best suspect is the wrong transmission fluid is being used.
