The brand of transmission fluid isn't the issue. We used to have Mercon for Fords and Dexron for everything else. Now there's Dexron2, ATF+6, and many others. I've heard stories of people having problems with what was listed as being for a certain transmission but still having problems. When I worked for a very nice family-owned Chrysler dealership, we always used transmission fluid from the manufacturer and never had fluid-related problems. Not all aftermarket brands cause problems, but when there are slipping, shuddering, and chattering problems, that's the first thing we ask about.
I suspect you have some other issue because that shuddering almost always occurred when the torque converter clutch locked up at around 35 to 40 mph. We didn't see problems at initial engagement like you described. To check for that torque converter shudder, drive in the highest gear with the engine warmed up, and close to 40 mph. Hold the accelerator perfectly steady, then lightly tap the brake pedal. Tapping the brake pedal will make the torque converter clutch unlock in preparation for slowing down, but then it will relock about two seconds later. If you feel the shudder each time it locks up, suspect the wrong type of fluid was used. To verify the converter unlocked, if you have a tach on the dash, you'll see engine speed increase about 200 rpm for those two seconds. If you don't have a tach, you might hear the engine speed pick up a little.
Apr 6, 2016 at 6:12 AM
