Transmission not working properly
150,673 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
STEVEKWASNY420
My friend has the vehicle listed above and you can shift it in reverse and drive nothing happens wont move in either gear, but when you put back in park make a grinding noise. anyone have any idea what the problem is?
May 30, 2021 at 8:16 AM
Good evening.
The sounds indicated the internals are working.
The most common issue with this grinding and no movement is one of the front axles has failed. If one axle is bad, it will not allow the car to move at all.
https://www.2carpros.com/articles/replace-cv-axle
I attached the procedure for replacing the axle shafts below. Inspect the axles to determine which one has failed.
Make sure you get it aligned when you are finished.
May 30, 2021 at 8:52 AM
STEVEKWASNY420
Okay, I'll check it out. they were thinking it might have been the neutral safety switch.
May 30, 2021 at 9:16 AM
No, that will never do that at all. That just controls the backup lights and the position of the shifter.
May 30, 2021 at 9:18 AM
STEVEKWASNY420
Okay, so most likely one of the axles are broken then should both be changed at once or how do you tell which side is broken?
May 30, 2021 at 9:21 AM
You can just replace the failed axle. Check the boots for any damage or leaking
You need to jack up the front end and put it on jack stands. Then start it up and put it in gear and see which axle is turning but the wheel is not turning.
May 30, 2021 at 9:59 AM
STEVEKWASNY420
Okay, thanks for all your help.
May 30, 2021 at 10:07 AM
You are welcome.
Always glad to help.
May 30, 2021 at 6:08 PM
