Transmission issues, code p0732
149,000 MILES • 6 CYL • 2WD • AUTOMATIC
NASER NASER
  • 836 POSTS
When cold drives nice and smooth, and even when warm you can go days sometimes with no issues, and then all of a sudden when you are about to slow down around second gear she downshifts hard, code p0732, i want to replace the fluid but i also want to see if this code is related to second gear solenoid and how to replace it, it's a shot in the dark but am willing to do it.
Sep 4, 2019 at 4:48 AM
  • 55,688 POSTS
The code is the problem which is for the input shaft sensor for the transmission. here is the location so you can change it out. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Sep 5, 2019 at 7:36 AM
NASER NASER
  • 836 POSTS
Hmm, that would be easy to change for sure, but why is it saying gear 2 incorrect ratio?
Sep 5, 2019 at 8:16 AM
  • 55,688 POSTS
Because the sensor is not working correctly. We might need to raise the car up. here is a guide that will help:
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Sep 7, 2019 at 5:36 AM
NASER NASER
  • 836 POSTS
finally was able to get the sensor and replaced it, took a minute to find it because it was under the shifter cable. cleaned two other sensors just in case. she is now in limp mode, and i have engine and transmission codes that are the same, o2 and knock sensor. At first when i drove it it jerked when i was slowing down once, and gave the p0732, and the others, cleared it and drove, limp mode as in probably third gear p0326, p0057 and p0137.
Nov 7, 2019 at 3:27 AM
  • 55,688 POSTS
It sounds like you have two issues. we will handle the transmission problem on this post. Can I ask if the speedometer is working correctly?
Nov 8, 2019 at 8:02 AM
NASER NASER
  • 836 POSTS
yes sir working.
  • 55,688 POSTS
It sounds like the transmission has gone bad or the fluid is low or burnt. here is a guide that can help:
Nov 8, 2019 at 8:07 AM
