Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer Sport Trac
Drivetrain
Transmission
Gear Selector
Stuck
Vehicle will not move with the transmission shifted into in any gear?
2002 FORD EXPLORER SPORT TRAC
152,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
KEPNER
MEMBER
1 POST
I drove it one day, the next day wouldn't move i put in all the gears.
Jul 2, 2020 at 8:43 PM
Experienced Mechanic
Good morning,
The first thing to do is to check the fluid level.
If that is okay, then I would drop the pan and change the fluid and filter as the filter may be clogged with debris.
Beyond that, it could be either the front pump or the torque converter that has failed. That would require removal of the transmission and inspection.
Jul 2, 2020 at 9:49 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
