Transmission problem
168,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
TORILYNN
Possible shift solenoid, leaking transmission fluid and will not shift from second to third. Any help is appreciated and if you have instructional pictures on repairing the problem please send those too.
Jan 22, 2018 at 7:36 AM
  • 55,770 POSTS
These transmission had a problem with the governor solenoid you must remove the pan which is sounds like it is leaking away here is a guide to help you see what you are in for when doing the job.
Check out the diagrams (Below)
Cheers, Ken
Jan 24, 2018 at 4:37 AM
