Transmission trouble
140,000 MILES • 4.6L • V8 • AUTOMATIC
SHERRY SEYMORE
It does not shift into second or third, but the fluid looks good.
The oil stays clean between changes.
Nov 11, 2017 at 8:19 AM
  • 55,721 POSTS
It sounds like you have a shift solenoid that is shorted out and not working.
Here is a guide to show you how to remove the pan so you can change the solenoid out:
It is the solenoid with the purple and orange wire.
You will need to lift the car up safely
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Cheers, Ken
Nov 13, 2017 at 3:26 AM
