Transmission issues
236,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
LORISSA PAYNE
My transmission started having trouble shifting into gears. It would shift but there would be a slight delay. I added some fluid but i guess i added too much because then it would not shift at all. I emptied some of the fluid and got it to the required level. Now the car will shift into first hard second is fine but it will not shift into third. There is also a really loud whistling noise when the car is on. I have check to see if i can find any broke vacuum lines, but i do not see any.
Jul 31, 2017 at 6:50 AM
  • 55,721 POSTS
Its sounds like you have a shaft speed sensor that is going out, Lets start by reading the codes. Here is a guide to help you get started and confirm.
Please run this test and get back to us we are interested to see what it is.
Cheers, Ken
Aug 2, 2017 at 6:50 AM
