transmission, interlock is executed and does not move
130,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
MOHAMMED96
  • 7 POSTS
The interlock is executed and does not move, knowing that the car was driven to a distance of about 12,000 km, and it used " 4low " depression for the column not present. The oil did not burn, or smelled.
Feb 14, 2020 at 12:04 PM
  • 110,248 POSTS
I'm not sure I understand what you are asking. Is there a problem with the shift interlock or is it with the transfer case?
Feb 14, 2020 at 12:45 PM
MOHAMMED96
  • 7 POSTS
The movement backward does not work, although the oil has no odor or discoloration.
Feb 14, 2020 at 1:10 PM
  • 110,248 POSTS
If reverse doesn't work, the first thing I would suggest is to have the computer scanned for diagnostic trouble codes. Either there is an issue with the transmission control module (TCM) which will show up with scanning, or there is a line pressure issue. Interestingly, the one clutch pack that engaged first gear also engages reverse. So I suspect it is something electrical and not hydraulic.
Have the scan done and let me know what codes are found. If there are none, then we will have to check line pressure.
Feb 15, 2020 at 10:56 AM
MOHAMMED96
  • 7 POSTS
A self-check was done by checking the Check Engine bulb, and reading that it was done and no malfunction code number, has appeared. what do you suggest about that?
Feb 15, 2020 at 1:39 PM
  • 110,248 POSTS
That will provide diagnostic trouble codes for the engine and not the transmission. Do you have access to a scanner that is able to read transmission codes?
Feb 16, 2020 at 8:34 AM
MOHAMMED96
  • 7 POSTS
Thank you my dear. I have to try to find it.
Feb 16, 2020 at 10:39 AM
MOHAMMED96
  • 7 POSTS
I don't have...
Feb 16, 2020 at 10:42 AM
  • 110,248 POSTS
I think you may have sent the last message to the wrong person. Let me know.
Feb 16, 2020 at 10:47 AM
MOHAMMED96
  • 7 POSTS
Thank you so much I make repay you can see it please
Feb 17, 2020 at 5:57 AM
MOHAMMED96
  • 7 POSTS
Did those codes for my transmission for reverts?
Code 743 okay.
Code 753 okay.
Code 1491 x.
Code 1388 x.
Code 1765 x.
I hope you can replay.
Thank you
Feb 28, 2020 at 7:06 PM
  • 110,248 POSTS
Yes, those codes are helpful. It seems there is a problem with voltage. Check and confirm all grounds are clean, the battery is fully charged, and there is no corrosion at points of contact.
Next, the codes related to the transmission are specific to a voltage issue. Check the transmission fuse and relay located in the power distribution box under the hood. See pics 1 and 2. I can't be sure, but I suspect the issue is the relay.
Here is a link that explains how to test a relay:
If you find all connections are good, then we need to check if power is getting to the transmission solenoid assembly. If there isn't, trace power to find loss. If there is power, replace the assembly. The solenoid assembly is located on the back side of the valve body. See pic 3
Let me know what you find.
By the way, these two codes are not related to the transmission.
1388 ASD
1491 Cooling fan circuit
Feb 29, 2020 at 8:33 AM
