tranismission not shiffting right when warm
20,000 MILES • AWD • AUTOMATIC
JWREED
transmission not shiffting right when warm. How do you change fluid?
Jun 20, 2015 at 12:06 AM
CARADIODOC
  • 34,413 POSTS
"Not shifting right" is wide open to interpretation. Your mechanic is going to need a much more detailed description than that. Most transmissions today require special equipment to add fluid. Unless there is a leak, changing the fluid won't fix a mechanical or electrical problem. The first step is to have the diagnostic fault codes read and recorded. Those will indicate the circuit or system that needs further diagnosis.
Jun 20, 2015 at 12:46 PM
