Transmission will not shift to first and second automatically
236,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
CPAGLIOCCHINI
The transmission operates fine if I shift from first to second manually, it goes through the rest of the gears after. So far I have changed the transmission shift solenoid.
Dec 23, 2018 at 7:08 AM
BRANDON SIMON
  • 49 POSTS
Have transmission inspected. Could be any number of issues and 99% of them are likely a transmission problem, i.e. worn gears, worn clutch, slipping, bad or blown seals, etc.
Dec 24, 2018 at 2:45 AM
