Tramission not going into reverse when engine is cool
200,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
WIZBONE
After changing the drive shaft of my car yesterday, while my engine is cool it does not go into reverse. I have to put on drive before going to reverse for it to work.
Oct 7, 2018 at 12:59 AM
Good morning.
Did you check the transmission level?
I would start by changing the oil/filter in the transmission. It may be dirt in the filter.
Oct 7, 2018 at 1:39 AM
WIZBONE
Okay, will try that today.
Oct 7, 2018 at 9:44 AM
Sounds like a plan.
Oct 7, 2018 at 9:51 AM
WIZBONE
Thank you very much. I change the oil and back to normal, thanks a lot.
Oct 8, 2018 at 6:44 AM
You are welcome.
Always glad to help.
Oct 8, 2018 at 6:45 AM
