Trailer wiring harness installation?
88,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
RBENNETT2
I am trying to replace a 4 pin trailer wiring harness with a new 7 pin . The new harness has 2 connectors, 1 with 5 wires and another with 2 wires (black and blue). The 5 wire end plugs into the existing receptacle but there is nowhere to connect the 2 wire connector. How do I connect it?
Aug 16, 2022 at 5:13 AM
  • 110,251 POSTS
When you say the wires are blue and black, is that on the new harness? I ask because those could differ based on the manufacturer.
I attached the wiring schematic for the trailer tow circuit for you to reference. I have a question. You have the five-pin connector connected, correct? If so, do you get power for all the lights such as signals, brakes, backup, and parking lights? If so, my guess is that the two-pin connector would be for an electric brake controller. Are you installing one?
Aug 16, 2022 at 12:42 PM
RBENNETT2
Hi Joe,
Thanks for responding. Yes, I have installed an electric brake controller. I do have the 5 pin connector connected. Everything works but the electric brakes on my travel trailer. I’m assuming because the other 2 wires are not connected to anything, and they are what operate the electric brakes.
Aug 16, 2022 at 2:07 PM
  • 110,251 POSTS
Yep, that sounds like the issue. If you have installed the brake controller, it should have a wiring schematic for installation. It has been a while, but I remember when installing them, I had to run new wiring from front to back from the controller and power.
Does the schematic you got indicate doing that?
Aug 16, 2022 at 2:20 PM
RBENNETT2
The schematic shows 2 connectors on the truck that connect directly to the 2 separate connectors on the wiring harness. I think the Tundra's with the complete tow package are equipped with the second connector. My Tundra doesn’t have the tow package. It does show that the blue wire included in the 2 wire connector controls the trailer brakes.
Aug 16, 2022 at 2:31 PM
  • 110,251 POSTS
I suspect you will need to run new wiring from the controller and power and make a connection to the one you have. If your vehicle didn't come with the trailer tow package, chances are that wiring just doesn't exist on your truck.
When you installed the new brake controller, was there a wiring schematic with it?
Aug 17, 2022 at 12:07 PM
