Trailer wireless harness not working
150,000 MILES • V8 • 4WD • AUTOMATIC
CDT35758
My vehicle is equipped with a seven-wire trailer towing harness. Harness is not active. The owner manual states that the fuses for those two circuits are installed in the under-hood electrical center, but the wires are not connected. Where can I find the wires that need to be connected?
Jul 3, 2022 at 11:03 AM
  • 110,248 POSTS
Are you referring to a factory harness that came with the vehicle? If that is the case, there will likely be a plugin for the harness under the rear of the vehicle (driver's side I believe) along the frame rail.
Let me know if that is what you are referring to.
Jul 4, 2022 at 4:51 PM
