Trailer brakes not working
308,000 MILES • 6.6L • V8 • TURBO • 4WD • AUTOMATIC
TOOTALL4247
Hello. I have an issue with my trailer brakes not working when I press the brake pedal. It works in manual override. Is there a wire on the brake pedal switch that sends voltage to the trailer brake controller when the pedal is pressed? If so what color is it? Thank you!
Jun 24, 2020 at 2:41 AM
Good afternoon,
I attached the wiring diagram for you to view. The white wire is the signal wire that should go to your controller.
Jun 24, 2020 at 4:28 AM
TOOTALL4247
That’s what I thought. I just tested it with a voltage tester. Thank you Roy!
Jun 24, 2020 at 4:41 AM
You are welcome.
We are always glad to help.
Jun 24, 2020 at 4:51 AM
