Traction light turned on and rear airbag light is also on
138,000 MILES • 2.4L • 5 CYL • 4WD • AUTOMATIC
KINGJD123
  • 104 POSTS
My traction control light is on and i have the 4x4 light i will send pictures, but what do you think? No check engine light on. when i accelerate i can hear the rear tires try to slip. CVT 2.5l. i'm not sure if it's related but i also have red airbag light on.
May 5, 2022 at 2:27 PM
Good morning,
There is a code set in the system that must be pulled to narrow the area.
The check engine light is for fuel controls not traction controls.
https://www.2carpros.com/articles/what-is-a-check-engine-light
Once you get the code, I can help narrow the area of failure.
May 5, 2022 at 8:00 PM
