service stabilitrak system, service traction control system, and engine power reduced warning
118,500 MILES • 5.3L • V8 • 4WD • AUTOMATIC
DALTONDAVIS2424
hi there,
Saturday i got a code on my dash reading, service stabilitrak system, service traction control system, and engine power reduced. so i started doing research on what could be wrong, and one person says it's spark plugs, so i change my spark plugs, one person says it's the OnStar system. so i disable the onstar system. i hard reset my truck, nothing has worked so far, so im looking for some insight.
Jul 12, 2021 at 9:04 AM
  • 110,248 POSTS
Spark plugs wouldn't cause this or the OnStar system. By chance, has the ABS light turned on or brake light? This type of issue is usually related to a wheel speed sensor failing. I have even seen the lights come on due to low brake fluid, so check that as well.
If you haven't, you should really have the CAN bus scanned. CAN stands for controller area network. Basically, all the computers/modules are tied together via a few wires. By performing this type of scan, it will identify a code regardless of the module it is stored in. In this case, it could be stored in the ABS module.
Here is a video showing how it is done:
https://youtu.be/InIlnsjOVFA
That is the easiest thing to do to confirm where the problem is coming from. If you want to check each wheel speed sensor manually, here is a link that shows how that is done:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Let me know if you have questions. If you have the system scanned, let me know what codes are found.
Let me know what I can do to help.
Jul 12, 2021 at 2:54 PM
