Traction control lights?
214,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
RODNEY CONAWAY
It will come on now and then light an beep, and it will pull to the right like brakes slammed on.
Aug 11, 2023 at 9:06 AM
  • 55,766 POSTS
Okay, i would lift the front end and grasp the right front wheel to see if the bearing hub is loose and if so, this is what is causing the problem of the transaction control light and the pull to the right.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Aug 12, 2023 at 7:31 AM
RODNEY CONAWAY
Thank you, I will try that!
Aug 12, 2023 at 8:06 AM
  • 55,766 POSTS
Please let us know what happens :)
Aug 14, 2023 at 4:10 AM
RODNEY CONAWAY
It was the bearing hub, thank you so much I'm going to tell my family, and friends about this.
Aug 15, 2023 at 6:49 AM
  • 55,766 POSTS
Thanks for letting us know, we are here to help, please use 2CarPros anytime. Can you please leave us a rating? (Copy entire link)
https://www.google.com/search?q=2carpros&gs_ivs=1#lrd=0x80dcd47364be5d0d:0xba091aa4209f4497,1,,,&tts=0
and
https://www.sitejabber.com/reviews/2carpros.com
Thank you in advance :)
Aug 16, 2023 at 4:22 AM
