You are very welcome. I'm glad you got it figured out. I don't know if you need them, but here are the directions for replacing that sensor. And, yes, it is directly tied into the EBCM. The attached pics correlate with the directions.
__________________________________________
2006 Pontiac Grand Prix V8-5.3L VIN C
Steering Wheel Position Sensor or Steering Shaft Lower Bearing Replacement
Vehicle Steering and Suspension Steering Sensors and Switches - Steering Steering Angle Sensor Service and Repair Procedures Steering Wheel Position Sensor or Steering Shaft Lower Bearing Replacement
STEERING WHEEL POSITION SENSOR OR STEERING SHAFT LOWER BEARING REPLACEMENT
Removal Procedure
pic 1
Caution: Refer to SIR Caution in Service Precautions.
1. Disable the SIR system.
2. Remove the steering column from the vehicle.
3. Remove the following from the steering shaft:
1. Steering shaft seal (1)
2. Sensor retainer (2)
3. Steering wheel position sensor (3).
pic 2
4. Remove the following from the steering shaft:
1. Lower spring retainer (1)
2. Lower bearing spring (2)
3. Lower bearing seat (3)
4. Adapter and bearing assembly (4)
Installation Procedure
pic 3
1. Install the following onto the steering shaft:
Important: The lower bearing seat must be in contact with the adapter and bearing assembly.
2. Lower bearing seat (3)
pic 4
3. Install the steering wheel position sensor (1).
Important: Align the slots of the sensor retainer (1) to the ribs of the adapter and bearing assembly. Push the sensor retainer (1) until it contacts the steering wheel position sensor.
pic 5
4. Install the sensor retainer (1).
5. Install the steering shaft seal (2).
6. Install the steering column to the vehicle.
7. Enable the SIR system.
____________________________________________________________________
Let me know if this helps and how you make out.
Take care and have a good Thanksgiving.
Nov 26, 2019 at 9:13 AM
