Traction control comes on randomly on right turns
150,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
TOOKIEN
  • 20 POSTS
I changed:
- Rear axle bearings and seals
- Rear LSD differential fluid (used 75w-90 synthetic)
- Front right wheel hub assembly (with sensor)
- Rotors and brakes (compressed calipers and bleed out entire system of air)
When I make right turns at higher speeds, the traction control (stabiltrack) goes on randomly. No ABS warning light comes on, only the stabiltrak.
No noises at wheel bearings. No play at wheels. Everything is firm.
Could it be:
- Lack of rear LSD differential GM oil additive?
- Defective new front ABS sensor?
- Some air left in ABS module?
- Some other issue?
Thank you for any help!
Dec 22, 2018 at 1:10 AM
  • 55,688 POSTS
It sounds like you have a wheel bearing hub that is going out which will cause the sensor to stop working. Here is a video to show you how to scan the ABS to confirm the issue and how to replace the hub step by step and diagrams below to how you how to fix it in your car:
https://youtu.be/rTtAnsOlZU4
and
https://www.2carpros.com/articles/bearing-hub-replacement
Check out the diagrams (below). Please let us know what you find.
Dec 24, 2018 at 5:22 AM
