Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Windstar
Tires
Pressure
traction control, abs, low tire pressure warning
2001 FORD WINDSTAR
120,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
ANDREW DOUGHERTY
MEMBER
1 POST
All three warning lights are on but the tire pressure is okay. Any suggestions as to the problem.
Jul 23, 2014 at 10:32 PM
HMAC300
Experienced Mechanic
might be tire sensor problem but have it reset if it can if not the sensors are bad.
Jul 23, 2014 at 10:39 PM
HMAC300
check battery for condition including load test as this can cause it too
Jul 23, 2014 at 10:40 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
