Traction control service light service Traction control and Stabil Trak and engine speed reduces.
Mar 4, 2023 at 3:18 AM
✓Experienced Mechanic
This usually happens when a front or rear bearing hub is going out which houses the ABS wheel speed sensor. The sensor cannot read correctly when the bearing fails due it its misalignment to the reluctor wheel. To find out which one let's use this guide and video to check the codes to see which speed or having the problem:
