Traction Control light on?
2011 GMC YUKON
111,225 MILES • 6.2L • V8 • 4WD • AUTOMATIC
CARA SWANSON
My service suspension/traction control message has been on for a while, and my traction control does not work. Also, the traction control light is on. Any ideas?
Nov 27, 2022 at 1:59 PM
  • 55,399 POSTS
It is probably a wheel speed sensor that is not working which is common, this can be caused by a bad bearing hub which houses the sensor. To find out which sensor is bad we need to run the codes with a CAN scanner, which is easy to do. You can get a CAN scanner (Controller Area Network) from Amazon from about $32.00.
here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
Amazon CAN scanner link:
https://amzn.to/3sX8MCX
Here is a video to show you how to change out the bearing hub and wheel speed sensor if needed:
https://youtu.be/ZgiPRG6jffc
Nov 28, 2022 at 5:20 AM
