Accelerating from a standstill the car zigzags and skids at turns at a speed of forty mph or over. Seems to be a stability issue.
Sep 11, 2016 at 8:02 AM
HMAC300
✓Experienced Mechanic
have front end checked you may have broken parts.
Sep 11, 2016 at 8:45 AM
HASSAN NAHLAH
MEMBER
My car is regularly serviced by the authorized agent in Sharjah. They thoroughly check and repair any fault found. As I hear from some sources that most American cars do not have the road grip or stability like the German cars. I wonder if a better sort of stabilizers might help.
Sep 14, 2016 at 7:59 AM
HMAC300
if it is a stability issue then it should be a sway bar problem and it also depends on how sharp a turn it is as you may be getting under or over steer. the American cars are mostly built for comfort whereas the German cars like a BMW are more of a sportier car so built differently.
Sep 14, 2016 at 8:05 AM
HASSAN NAHLAH
MEMBER
Thanks for your help. I will have this checked.
Sep 14, 2016 at 8:16 AM
Please let us know what you find so it will help others.
