Track light on
200,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
SKOOTER24
  • 275 POSTS
The track light is on the dash.
Feb 28, 2021 at 8:23 AM
NICKOLAOSF
  • 69 POSTS
Hi SKOOTER24,
We can help you with this information. (Engine size do you mean 1.5?) On the Yaris you have a switch make sure it is not in the off position. Check out the diagrams (below).
Let us know what happens and please upload pictures or videos of the problem.
(you will have to scan systems for codes) I am glad to help you, If there is anything else we can help you with please contact us again. This guide can help you with the codes.
Thank you for choosing 2CarPros. Cheers, Nick
Feb 28, 2021 at 10:43 AM
SKOOTER24
  • 275 POSTS
I tried pressing it and it did nothing.
Feb 28, 2021 at 11:03 AM
NICKOLAOSF
  • 69 POSTS
Okay, SKOOTER24,
You started vehicle running and pressed traction control button and light stays on regardless.
Now you have to scan to read any trouble codes in system (scan ABS system as well)
Cheers, Nick
Feb 28, 2021 at 11:33 AM
SKOOTER24
  • 275 POSTS
Okay, so I need to unhook the traction control switch and test those pins?
Feb 28, 2021 at 11:39 AM
NICKOLAOSF
  • 69 POSTS
The first thing is to scan systems for codes (if you don't have a scanner parts stores read it for you for free, if there is a code snap a picture with your phone, do not erase)
If there is no codes you have to remove switch and measure to verify if it is working.
Cheers, Nick
Feb 28, 2021 at 12:09 PM
