Track light on
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
SKOOTER24
  • 275 POSTS
The track light is on the dashboard.
Feb 27, 2021 at 7:53 AM
  • 110,248 POSTS
Chances are one of the wheel speed sensors has failed. Here is what I suggest, you can scan the can-bus system to retrieve all codes or check each sensor to see if you can locate a bad one.
Here is a video showing how to scan the can system:
https://youtu.be/InIlnsjOVFA
Now, you can check each sensor with a multimeter or voltmeter. Here is a link that shows how it's done:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
I attached two pics below showing the location of the front and rear sensors.
If you find one is bad, here is a link that shows in general how they are replaced.
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
Here are the directions specific to your vehicle. The remaining pics correlate with the directions.
_______________________
Front:
2012 Toyota Yaris Sedan L4-1.5L (1NZ-FE)
Front Speed Sensor (Sedan) - Removal [08/2011 - ]
Vehicle Sensors and Switches Sensors and Switches - Brakes and Traction Control Wheel Speed Sensor Service and Repair Removal and Replacement Front Speed Sensor (Sedan) - Removal [08/2011 - ]
FRONT SPEED SENSOR (SEDAN) - REMOVAL [08/2011 - ]
BRAKE CONTROL / DYNAMIC CONTROL SYSTEMS: FRONT SPEED SENSOR (for Sedan): REMOVAL; 2012 MY Yaris [08/2011 - ]
DISCONNECT CABLE FROM NEGATIVE BATTERY TERMINAL
REMOVE FRONT WHEEL
REMOVE FRONT FENDER LINER
Remove the 3 screws, 6 clips and 4 grommets and remove the front fender liner.
REMOVE FRONT SPEED SENSOR
pic 1
Remove the speed sensor clip from the body.
Disconnect the speed sensor connector.
Remove the 3 clips.
Remove the bolt and separate the clamp from the body.
Remove the bolt and separate the clamp from the shock absorber.
Remove the bolt and remove the speed sensor from the steering knuckle.
NOTICE:
Keep the speed sensor tip and installation portion free of foreign matter.
Remove the speed sensor without turning it from its original installation angle.
Install is the reverse of removal.
Rear:
Rear Speed Sensor (Sedan) - Removal [08/2011 - ]
Vehicle Sensors and Switches Sensors and Switches - Brakes and Traction Control Wheel Speed Sensor Service and Repair Removal and Replacement Rear Speed Sensor (Sedan) - Removal [08/2011 - ]
REAR SPEED SENSOR (SEDAN) - REMOVAL [08/2011 - ]
BRAKE CONTROL / DYNAMIC CONTROL SYSTEMS: REAR SPEED SENSOR (for Sedan): REMOVAL; 2012 MY Yaris [08/2011 - ]
REMOVE REAR WHEEL
REMOVE REAR BRAKE DRUM SUB-ASSEMBLY [ BRAKE (REAR): REAR BRAKE (for Sedan): REMOVAL+ ]
DISCONNECT SKID CONTROL SENSOR WIRE [ AXLE AND DIFFERENTIAL: REAR AXLE HUB (for Sedan): REMOVAL+ ]
REMOVE REAR AXLE HUB AND BEARING ASSEMBLY [ AXLE AND DIFFERENTIAL: REAR AXLE HUB (for Sedan): REMOVAL+ ]
________________________
I hope this helps. Let me know if you have other questions.
Take care and God Bless,
Feb 28, 2021 at 11:15 AM
SKOOTER24
  • 275 POSTS
Well there is a switch and it doesn't do anything.
Feb 28, 2021 at 11:36 AM
SKOOTER24
  • 275 POSTS
The button for the traction control doesn't do anything when I press it.
Mar 1, 2021 at 5:04 AM
  • 110,248 POSTS
Chances are the switch is bad. You will need to check it for continuity. Are you able to do that? Here is a link that explains how to test wiring. It discusses continuity.
Mar 1, 2021 at 8:36 AM
SKOOTER24
  • 275 POSTS
Yeah, I need to check between 6 and 3 correct?
Mar 1, 2021 at 10:48 AM
  • 110,248 POSTS
Where are you checking that? If it is at the switch, then you are likely correct.
Mar 1, 2021 at 12:27 PM
SKOOTER24
  • 275 POSTS
Yes, at the switch I think those are the correct pins to check.
Mar 1, 2021 at 12:30 PM
  • 110,248 POSTS
If it's right at the switch, chances you're correct. Remember to check it in both positions.
Let me know what you find.
Mar 1, 2021 at 12:32 PM
SKOOTER24
  • 275 POSTS
Okay, I will. thank you so much.
Mar 1, 2021 at 12:35 PM
  • 110,248 POSTS
You are very welcome. Let me know what you find.
Mar 2, 2021 at 3:30 AM
