Trac off light and ABS light
145,000 MILES • 6 CYL • FWD • AUTOMATIC
DSTEFANO
Trac off light and ABS light will come on and blink periodically and then turn off.
Jul 12, 2015 at 11:43 AM
  • 110,248 POSTS
The most common cause of the two coming on together is a failed wheel speed sensor. What I would suggest is to check each one of them to see if one has failed. If you look at pic 1 below, it shows how they are located on both the front and back.
To check one only requires a voltmeter or multimeter. Here is a link that shows how it is done:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
If you find one is bad, here are the directions for replacement. The attached pics correlate with the directions.
_______________________________________
Front Sensor
1998 Lexus ES 300 V6-3.0L (1MZ-FE)
Speed Sensor, Front
Vehicle Sensors and Switches Sensors and Switches - Brakes and Traction Control Wheel Speed Sensor Service and Repair Procedures Speed Sensor, Front
SPEED SENSOR, FRONT
pic 3
REMOVAL
1. Disconnect speed sensor connector.
a. Remove the fender liner.
pic 4
b. Disconnect the speed sensor connector.
pic 5
2. Remove speed sensor.
a. Remove the bolt, flexible hose and speed sensor harness clams from the shock absorber.
Torque: 29 Nm (21 ft. lbs.)
b. Remove the resin clip and clamp bolt holding the sensor harness to the body.
Torque: 5.4 Nm (48 inch lbs.)
c. Remove the speed sensor from the steering knuckle.
Torque: 7.8 Nm (69 inch lbs.)
INSTALLATION
Installation is in the reverse order of removal. After installation, check speed sensor signal.
Rear Sensor
Speed Sensor, Rear
Vehicle Sensors and Switches Sensors and Switches - Brakes and Traction Control Wheel Speed Sensor Service and Repair Procedures Speed Sensor, Rear
SPEED SENSOR, REAR
pic 6
REMOVAL
pic 7
a. Remove the seat cushion and seatback.
b. Disconnect the speed sensor connector, and pull out the sensor wire harness with the grommet.
pic 8
a. Remove the 2 clamp bolts holding the sensor wire harness to the body and shock absorber.
b. Remove the speed sensor from the axle carrier.
INSTALLATION
_________________
I hope this helps. Let me know if you have other questions.
Dec 25, 2020 at 2:11 PM
