Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
Accord
Engine
Throttle Body
Throttle Position Sensor
Replace/Remove
TPS sensor installation instructions needed
2002 HONDA ACCORD
227,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
HUNTER JOHNS
MEMBER
I need to know step by step how to put a new TPS sensor on my car. I don’t know how to do the voltages and all. please and thank you.
Feb 19, 2021 at 6:46 AM
HUNTER JOHNS
MEMBER
I’m just having a code P0122 circuit low code after I put it on.
Feb 19, 2021 at 7:48 AM
Experienced Mechanic
This could be the sensor but there are some other possible causes as well so it is a good idea to run through this testing to find out for sure.
Below is the testing that we need to do and the location of the sensor which should give you what you need.
Let us know what you find with this and we can go from there. Thanks
Images (Click to enlarge)
Feb 19, 2021 at 9:59 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
