tps sensor
270,000 MILES
LEIGHAGREEN
if this sensor goes bad will it shut down fuel flow
Apr 25, 2013 at 12:05 AM
JDL
  • 16,098 POSTS
It won't shut down the fuel pump, as far as I know. If your having fuel issues, check fuel pressure.
What kind of problem are you having? What makes you think the tps has a problem?
Apr 25, 2013 at 12:47 AM
RONNIE GROVER
When it's cold, will crank right up and run fine. After warm up, skips and sputters like it has jumped time when you try to accelerate
Jan 14, 2018 at 9:00 AM
  • 55,721 POSTS
it sounds like you have an engine coolant temperature sensor that has gone out but to be sure can we run the codes to see what come up? Here is a guide to help us get started.
Cheers, Ken
Jan 17, 2018 at 2:14 AM
