Tps failure
170,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
KIMOPORTER
My car was running and in park when it started showing all signs of TPS failures. What do I need to check?
Mar 19, 2018 at 4:56 PM
  • 31,937 POSTS
You may get a code, you can also check the TPS with a live data scanner as this will shop throttle percentage as you open the throttle, no response with throttle on scanner will be fairly conclusive.
Mar 19, 2018 at 5:30 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
If you do not have a scan tool you could use a multi-meter.
Circuit/system testing:
Ignition OFF, disconnect the harness connector at the throttle body. Allow up to two minutes for the ECM to completely power down.
Ignition OFF, test for less than 5 ohms of resistance between the low reference circuit terminal C and ground.
If greater than 5 ohms, test the low reference circuit for an open/high resistance. If the circuit tests normal, replace the ECM.
Ignition ON, test for 4.8-5.2 volts between 5-volt reference circuit terminal E and ground.
If less than 4.8 volts, test 5-volt reference circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the ECM.
If greater than 5.2 volts, test the 5-volt reference circuit for a short to voltage. If the circuit tests normal, replace the ECM.
Verify the scan tool TP sensor 1 voltage is less than 0.1 volt.
If greater than 0.1 volt, test the signal circuit terminal D for a short to voltage. If the circuit tests normal, replace the ECM.
verify the scan tool TP sensor 2 voltage is greater than 4.8 volts.
If less than 4.8 volts, test the signal circuit terminal F for a short to ground. If the circuit tests normal, replace the ECM.
Install a 3A fused jumper wire between the signal circuit terminal D and the 5-volt reference circuit terminal E of the TP sensor 1. Verify the TP sensor 1 voltage is greater than 4.8 volts.
If less than 4.8 volts, test the TP sensor 1 signal circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the ECM.
Install a 3A fused jumper wire between the signal circuit terminal F and the low reference circuit terminal C of the TP sensor 2. Verify that the TP sensor 2 voltage is less than 0.1 volt.
If greater than 1.0 volt, test the TP sensor 2 signal circuit for a short to voltage or an open/high resistance. If the circuit tests normal, replace the ECM.
Ignition OFF, disconnect the harness connector at the ECM.
Test for less than 5 ohms of resistance on all TP sensor circuits between the following terminals:
ECM C2 signal circuit terminal 65 to TP terminal D
ECM C2 signal circuit terminal 63 to TP terminal F
ECM C2 5-volt reference circuit terminal 3 to terminal E
If greater than 5 ohms, repair the affected circuit for open/high resistance.
Test for infinite resistance between TP sensor 1 signal circuit terminal D and TP sensor signal circuit terminal F.
If less than infinite resistance, repair the short between TP sensor 1 signal circuit and TP sensor 2 signal circuit.
If all circuits test normal, replace the throttle body.
Mar 20, 2018 at 1:43 AM
KIMOPORTER
I totally disconnected the battery and replaced all plugs and wires. so do I have to relearn the TPS sensor and PCM?
Mar 20, 2018 at 2:27 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
I would say no. If the engine runs rough do drive it around for twenty minutes or so but I think the PCM will hold that memory in like a read only memory, which has to be flashed in order to overwrite and usually is not lost when losing the battery, like on the older types OBDI.
Mar 20, 2018 at 2:41 AM
