TPS/ETC/throttle control sensor error
198,678 MILES • 5.7L • V8 • 4WD • AUTOMATIC
PHENIOX
Do I have to change out my whole throttle body or can I just change out the sensor?
Jun 8, 2019 at 4:47 AM
Hi Pheniox,
Unfortunately you need to change the entire throttle body. The sensor is part of the assembly.
I attached the process for removing it and installing it. Also, a screen shot of the part itself that shows the TPS on the side of the throttle body.
Let me know if you need more information. Thanks
Jun 8, 2019 at 5:29 AM
