TPMS sensor installation?
90,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
BEBOBEBO
  • 116 POSTS
My car listed above dash only shows indicator when tire pressure is low , but I will install android head unit that supports TPMS pressure gauge reading.
My first question is there a method to keep original TPMS sensor and make them read gauge in new android head unit, or should buy new sensors.
My second question can i install new external sensor for android and at same time keeping old original sensors in My second question is can I install a new external sensor for Android and at the same time keep the old original sensors in position?
Jan 27, 2025 at 3:11 AM
  • 110,248 POSTS
The TPMS in each wheel does nothing but emit an RF signal which a receiver uses to determine the information.
I'm not familiar with what you are adding, but I suspect you should be able to input a radio frequency into the product from each sensor, so it is recognized.
Let me know your thoughts and if possible, take a few pics of what you are installing and upload them for me to see.
Jan 27, 2025 at 10:43 AM
