TPMS reset
43,000 MILES • V6 • 4WD • AUTOMATIC
DHUDSON002
how to reset the tire pressure monitors after rotating tires?
Feb 19, 2018 at 6:13 AM
STEVE W.
  • 15,418 POSTS
That system should relearn the positions automatically once it has been setting still for at least twenty minutes then driven nonstop at a speed faster than twenty mph for at least twenty minutes.
Or you can use a TPMS tool to trigger the sensors and relearn the positions.
The TPMS will continue to warn the driver of low tire pressure as long as the condition exists, and will not turn off until the tire pressure is at or above recommended cold tire placard pressure. Once the low tire pressure warning has been illuminated, the tire pressure must be increased to the recommended cold tire pressure in order for the Tire Pressure Monitoring Telltale Light to be turned off.
NOTE: When filling warm tires, the tire pressure may need to be increased up to an additional 4 psi (30 kPa) above the recommended cold placard pressure in order to turn the Tire Pressure Monitoring Telltale Light off.
The system will automatically update and the Tire Pressure Monitoring Telltale Light will extinguish once the updated tire pressures have been received. The vehicle may need to be driven for up to 20 minutes above 15 mph (24 km/h) to receive this information.
Feb 19, 2018 at 6:24 AM
DHUDSON002
Thanks.
Feb 19, 2018 at 7:23 AM
