Where is the TPMS module control located, my tire pressure sensors are not communicating?
2007 HYUNDAI SONATA
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
ROBERTG2011
Hello Car Pros,
My tire pressure sensors are not communicating with the TPMS module.
Sensors are sending signals.
Should i replace the TPMS module?
I can't find the location of the module.
if there is a reset button. Where?
Diagrams would be helpful.
thanks,
Robert
Oct 1, 2024 at 2:30 AM
  • 55,423 POSTS
Hi Robert,
I would try a hard system reboot fuse and check the three fuses in the inside fuse panel which I have included in the diagrams below. If okay, here is the location of the TPMS control module so you can check it out.
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
and
Check out the images (below). Let us know how it goes.
Oct 1, 2024 at 8:53 AM
