TPMS relearn
66,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
JOEGOMEZ_78130
I need to replace my vehicle in learn mode so I can relearn the TPMS. I will be using a EL-50488.
OEC-T5 tool. Thanks
Dec 24, 2019 at 5:47 AM
This system has an auto learn system. So it needs vehicle speed over 20 MPH for 20 minutes to learn new sensors. I attached the detail from the manual. Let me know if you have questions.
I am sure there is a way to manually enter the learn mode on the OEM scan tool but that detail is not in the service manual.
Dec 24, 2019 at 12:20 PM
JOEGOMEZ_78130
Been trying for the last couple of days still cannot make work. any other ideas?
Dec 30, 2019 at 9:09 AM
Is the tire light on? Have you checked for codes? If the light is not clearing then I suspect there is still another issue with the system.
Dec 30, 2019 at 9:58 AM
