2007 Toyota Yaris stereo
BSIBBS
Electrical problem
2007 Toyota Yaris 4 cyl Front Wheel Drive 180000 miles
sometimes stereo will work fine other times it will not work at all or it will work and the liquid crystal display will look all messed up seems to happen when its very hot! help thanks barry l sibbitts
Aug 5, 2010 at 12:20 AM
MMPRINCE4000
  • 8,548 POSTS
Start by checking fuses, otherwise the radio will have to be removed.
Could be a fuse that has worked loose and is causing an intermittent contact.
Sep 17, 2010 at 12:32 AM
