When transmission is shifted into second gear there is a vibration
240,000 MILES • 2.0L • 4 CYL • MANUAL
MATAITSANE
The car vibrates when you put it in second gear. It making the same like when you prematurely move to a higher gear. Toyota Venture or Stallion
Jun 10, 2022 at 7:57 PM
  • 110,244 POSTS
Can you confirm the model for me? Also, if you shift to third, do you experience anything? Is the check engine light staying on while the engine is running?
Oftentimes, this type of issue is due to a universal joint or CV joint. However, I'm not sure what model we are dealing with.
Take a look through this link and let me know if you experience any of the things mentioned:
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
https://www.2carpros.com/articles/how-u-joints-work
Jun 11, 2022 at 1:33 PM
