2003 Toyota Van Rear Axle(suspect)- Fault diagnosis
LEOPAUL
Transmission problem
2003 Toyota Van 4 cyl Two Wheel Drive Manual 75000k miles
Dear Sir,
I shall be grateful if you could give me your expert advice to rectify the following problem.
My Toyota Townace KR42 emits a metalic sound (an audible metalic clunk) from rear when starting to move forward or backwards ( from parked position) and also while coasting below 45 kmph when accelarating or decelearating sometimes.The vehicle is in good condition except for this noise which developed 2 months back.
Toyota Company checked the Crown wheel /Pinion backlash and found to be within limits.Yet without success.Agents advised to replace the Crown wheel / Pinion assembly.Parts are not available.
Sir, I thank you for your valuable time in this regard and looking forward to hear from you.
Best Regards
Leo
Feb 22, 2010 at 5:44 PM
  • 31,937 POSTS
Hi there,
The type of noise you describe is more constant with a faulty universal joint, i would be inspecting these first.
mark (mhpautos)
Feb 22, 2010 at 6:04 PM
LEOPAUL
[quote:698bf32669="mhpautos"]Hi there,
mark (mhpautos)[/quote:698bf32669]
Sir,
Thanks for kind advice.The two piece type propeller shaft and 3 universal joints are sound.
I intend removing the propeller shaft assembly,centre bearing assembly and checking splines of drive pinion flange/universal joint sleeve yoke with an trusted mechanic.The noise comes with first forward movement. Thereafter no sound with the release of the clutch in forward direction. If moving backward sound is heard.Could it be some component getting stuck and being released.
Appreciate your kind opinion
Best Regards
Leo
Feb 23, 2010 at 2:26 PM
  • 31,937 POSTS
Hi there,
If the uni's are all sound, the next place i would be checking is all the rear suspension mounts, it may be something moving with weight transfer when drive is taken up, what you can try is to have the car on a slight decline, place in gear and put the clutch in, with hand brake off allow the car move a little then let clutch off, this will give a slight pre load to the diff pinion, do a down Hill hand brake start trying to take up load before releasing hand break, with the pre load taken up in the diff any noise on drive away should be suspension based, wort a try...
Mark (mhpautos)
Feb 23, 2010 at 2:49 PM
