The oil pressure gauge takes 5-8 seconds to move after starting engine then shoots to the middle mark and never moves. I took it to Toyota under warranty. They replaced the sender unit ( near oil filter) and even replaced the entire center pod of the dash. After keeping the vehicle for a week they said that it was “normalâ€. I know that it is not normal. I have only experienced excessive valve/lifter noise on start up 1 time. I am worried that the oil is not circulating quickly enough on start up. What can be done ? Thank you
Apr 8, 2010 at 4:39 AM
