2003 Toyota Tundra bleeding
FREDDIE 55
Brakes problem
2003 Toyota Tundra V8 Two Wheel Drive Automatic
caliper change bleeding front
Feb 7, 2010 at 2:04 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Turn the ignition switch to ON, and wait until the pump motor has stopped.
Connect the vinyl tube to the brake caliper.
Depress the brake pedal several times, then loosen the bleeder plug with the pedal held down.
At the point when the fluid stops coming out, tighten the bleeder plug, then release the brake pedal.
Repeat until all the air in the fluid has been bled out.
Repeat the above procedures to bleed the other brake line.
Apr 22, 2010 at 2:45 PM
