2002 Toyota Tundra Replacing Front hub assembly bearing?
2002 TOYOTA TUNDRA
140,000 MILES • V8 • 4WD • AUTOMATIC
HADDENSIMPSON
I'm replacing the bearing for the front hub assembly and need to know how to do it? how to take it apart and put the new one in? Will I need a press?
Feb 4, 2010 at 12:54 PM
RACEFAN966
  • 5,029 POSTS
OK this is no easy task from the looks of it. Yes you need a press to press the bearing out and back in. You have to loosen the axle nut, remove the caliper and unbolt the ball joints and remove the front knuckle as a unit then press the bearing out and press the new one back in. Here is a pic of how the bearing is done once the knuckle is out.
https://images.2carpros.com/forum/automotive_pictures/249564_Graphic_194.jpg
Feb 5, 2010 at 2:22 AM
