2001 Toyota Tundra Rotors & Brakes
2001 TOYOTA TUNDRA
89,923 MILES • V8 • 2WD • AUTOMATIC
IMHARVEY
I need to replace my rotors & Brakes & have replaced the stock toyota rotors 3 times in 89,000 miles since they continually warp and have decided to try either slotted, cross drilled, slotted & dimpled rotors any ideas or suggestions on this matter?
Oct 30, 2009 at 9:24 AM
MERLIN2021
  • 17,250 POSTS
I always had good lusk with Brembo, but you can try crossdrilled. How are the calipers? If they drag, it can overheat the rotors...just a thought.
Oct 30, 2009 at 9:55 AM
IMHARVEY
Rotor warping has been an ongoing problem since it was new. I just had a 90,000 service at a dealership and was told that the rotors were 25.5mm thick and should not be under 26mm thick, so I decided to check into replacing the rotors, maybe I should look at calipers also.
Oct 31, 2009 at 4:12 AM
MERLIN2021
  • 17,250 POSTS
70,000-80,000 calipers usually start to gunk up internally...
Oct 31, 2009 at 5:24 AM
