2001 Toyota Tundra fuses
130,000 MILES • V8 • 2WD • AUTOMATIC
WGUERIN
i would like to know if there is a power fuse that i can pull that disconnect power to my dashboard..
thanks
Oct 29, 2010 at 11:04 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
What exactly are you trying to kill power to? There are separate fuses for several things on the dashboard. Radio fuse, gauge fuse, lights etc..
Oct 29, 2010 at 11:20 AM
WGUERIN
im trying to kill the power to the computer and alarms system..
thanks
Oct 30, 2010 at 6:31 AM
BLUELIGHTNIN6
  • 16,542 POSTS
If you kill power to computer the vehicle will not start, I'm assuming you know that ..Is there a particular reason why you are doing that ?
Oct 30, 2010 at 6:39 AM
WGUERIN
i've removed the fuse to the ECU..that should do it. thanks
Nov 8, 2010 at 8:37 AM
