2000 Toyota Tundra starts but dies sometimes
118,000 MILES • V8 • 4WD • AUTOMATIC
WOODY1973
my truck just started doing this about 2 months ago.i have no engin light on,i have repaced the p.v.c valve,in line fuel filter,spark plugs cleaned the mass flow air senser with spay cleaner from auto part store.it sometimes will start then die then i will try starting it again and it will start and almost die but then stay running. sometimes when i come to a stop light it almost dies also sometimes when i try to start it will act like its going to start but wont. could it be my fuel pump?
Mar 28, 2010 at 9:27 AM
  • 75,988 POSTS
Clean out the idle air control valve and test the throttle position and coolant temperature sensor also clean out the EGR valve
Mar 28, 2010 at 9:45 PM
