2000 Toyota Tundra changing bearings
2000 TOYOTA TUNDRA
115,000 MILES • 6 CYL • 2WD • MANUAL
SPUD3369
I have a whirl-whirl noise coming from the rear of the truck on deceleration between 50 mph and 30 mph. I tried changing the rear u-joint but no improvement. I then raised the rear wheels and put it in gear and I heard a similiar noise coming from the rear. I assume it must be the wheel bearings. Is there any special tools I will need to do this job, such as a torch or press? Will a basic set of hand tools do? Are there any tips you can give me before I begin? Are there any torque settings I should retighten any of the bolts at?
Nov 28, 2009 at 5:49 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Remove the rear wheel, and rear brakes.
If equipped, remove the Antilock Brake Sensor (ABS) from the rear axle assembly.
Disconnect the brake line and parking brake cable.
Remove the four backing plate mounting nuts and pull the axle shaft from the housing.
Remove the bearing retainer and antilock brake sensor rotor (differential side) by threading a nut over the bolts and lightly tapping with a hammer.
Do NOT reuse the nuts removed from the vehicle.
Grind the ABS sensor retainer and rotor surfaces, and then chisel them out.
Place washers and four new nuts over the serration bolts and tighten the bolts to install the serration bolts to the backing plate.
Remove the four bolts from the serration bolts.
Remove the snapring.
Remove the axle shaft from the backing plate.
A special service tool (SST part number 09521-25011) will be needed to remove the rear axle shaft and bearing retainer from the backing plate. After the axle is removed, disconnect the service tool.
Remove the outer oil seal.
Remove the rear axle bearing.
Remove the inner oil seal
To install:
Install the inner oil seal with the proper seal driver.
Install the rear axle bearing and outer seal.
Place the axle shaft and a new bearing retainer into the backing plate.
Replace the snapring.
Bleed the braking system and check for leaks.
Install a new ABS speed sensor rotor and retainer (differential side).
Replace the rear axle shaft assembly.
Connect brake line and parking brake cable.
Install the ABS sensor into the rear axle housing.
Install the rear brake assembly.
Replace the brake drum and rear wheel.
Dec 24, 2009 at 11:42 AM
