2000 Toyota Tundra brakes surging
2000 TOYOTA TUNDRA
185,000 MILES • V8 • 2WD • AUTOMATIC
GNIDIR
I had the toyota house turn my rotors a couple of yeas ago and since that time when I start to stop it feels as if my brakes are surging or maybe the rotors are warped. At the time of repair I had them turn the rotors and put new pads on. I have heard this is common on the 2000 Turndra. Will replacing the rotors and new pads correct the problem?
thanks
Darrell
Apr 8, 2009 at 11:23 PM
If its vibrating and the brake pedal pulsating while braking
Apr 8, 2009 at 11:30 PM
  • 31,937 POSTS
HI there,
If you mean that the pedal is pulsating under braking, this is a fault with a rotor, replacing the rotors and pads will fix tis problem.
mark (mhpautos)
Apr 8, 2009 at 11:33 PM
