1988 Toyota Trueno Clutch
FILIBERTO
Transmission problem
1988 Toyota Trueno
I installed a MR 2 engine in the car, can I use the original transm and clutch
Nov 5, 2009 at 12:17 PM
THIS IS MIKE
  • 686 POSTS
checking with a salvage yard should help you find out if you can swap the engine and still use your old transmission. Often times their are many issues with swapping engines and providers of used engines have the compatibility of differents powerplants and transmissions.
Nov 9, 2009 at 8:18 AM
